mixture model, Problem with negative volume fractions
Posted May 13, 2011, 11:39 a.m. EDT 2 Replies
i try to model the settling of sand grains in a fluid due to gravity (suspension of sand and oil). I use the mixture model laminar flow.
The 2d-domain contains 3 noslip-walls and 1 slip-wall (upper wall). All walls are with "no dispersed phase flux" condition. The slip-velocity follows "Hadamard-Rybczinski" and the mixture viscosity with "Krieger-type".
The intial velocities are zero and the pressure ist constrained to zero at the upper corner-points.
The initial volume fraction of the dispersed phase is 0.1 all over the domain and the maximum volume fraction is 0.62.
The solution has to be time-dependent an the solver MUMPS is used. The time discretization comes from "generalized alpha".
The model is attached.
The calculation starts without problems, but after a while negative volume fractions appear. Later on, volume fractions greater as the specified maximum appear.
Now the time steps decrease rapidly and the solver stops without convergence.
How can we avoid these senseless volume fractions, maybe they are the cause of my problem?
How can we tune up the solver to get faster results?
Thanks for your help!
with best wishes
Uwe
Hello Uwe Glaubach
