Hello Sanket Jain
Oct 5, 2011, 7:47 a.m. EDT
Hi everybody,
I've got a similar problem: I want to export the single domain meshes (via the Matlab livelink, where I will have to refer to the mesh node tags).
To do this, I've to define multiple mesh nodes under the mesh branch. But it seems that the single mesh nodes are somehow independent one from each other.
For example, I have 2 blocks and I mesh the first one with a mesh node. Then, I add a second mesh node and I select 'Remaining'. At this very point, the second block is meshed but the first block is meshed again, as if the first mesh node didn't exist.
Therefore, my question is:
- how I can I make the mesh nodes behave in a complementar way? I need different mesh nodes because each of them has a different tag which I can refer to in Matlab.
Thank you in advance for any help.
PM
Hi everybody,
PM
Oct 5, 2011, 10:44 a.m. EDT
Sorry! I can't be of much help. I used xmeshinfo in 3.5a to take out the co-ordinates and connections of the mesh. Generally, the 5th column of the connection indicated the domain to which each element belong to. I think I used that to find the domain number.
Generally in 4.1, all previous function of 3.5a are preceded by 'mph'. But I haven't tested for it yet!
Lars Gregersen
COMSOL Employee
Oct 7, 2011, 7:34 a.m. EDT
In Comsol 4.2 you'll find the function mphmeshstats that will return the information you need for the meshes.
Comsol 4.2 also added a new function mphxmeshinfo that makes access to the xmeshinfo easier. However, for the xmeshinfo there is no easy way to obtain the information from independent domains separately. Write to support if you need help with this.
Lars Gregersen
Comsol Denmark
Lars Gregersen
Comsol Denmark
