Working with Geometric measurements tool
I'm trying to get the area of a boundary, unfortunately without success.
Reading the help for measurement tool in the API document (P.151), I can conclude to the following code lines:
ie: to measure a face on a single block
__________________________________________________________________
model.geom('geom1').measure.selection.init(2);
model.geom('geom1').measure.selection.set('blk1', [4]); % Measure face #4
model.geom('geom1').measure.getArea(4);
This code sequence generate error : No appropriate method, property, or field getArea
The only line on which help document is passing quickly over is the last one: I don't know how to correctly write this line. getBoundaryArea, getArea ?
2 Replies Last Post Jul 11, 2014, 1:50 a.m. EDT
Hello Gabriel Caron
Posted: 1 decade ago Sep 6, 2011, 1:14 p.m. EDT
Finally, to get the area :
model.geom('geom1').measureFinal.selection.geom('geom1', 2);
model.geom('geom1').measureFinal.selection.set([4]);
model.geom('geom1').measureFinal.getVolume
Finally, to get the area : model.geom('geom1').measureFinal.selection.geom('geom1', 2); model.geom('geom1').measureFinal.selection.set([4]); model.geom('geom1').measureFinal.getVolume
Posted: 1 decade ago Jul 11, 2014, 1:50 a.m. EDT
Hello Gabriel,
I know its been so long since your post but I am posting here since I couldn't find any relavant post about this.
I want to measure the length of an edge, area of a boundary etc. using the measurement tool in COMSOL. I found out that using the following syntax:
model.geom(<geomtag>).measure.selection.named(<edgeselectiontag>)
in Matlab Livelink does not actually return the edge length. It just returns the following but not the actual length of the edge.
Dimension 1: Geometry Geometry; Domain 31
Is there a way to get the value of actual dimension into the matlab workspace?
Thanks!
Hello Gabriel, I know its been so long since your post but I am posting here since I couldn't find any relavant post about this. I want to measure the length of an edge, area of a boundary etc. using the measurement tool in COMSOL. I found out that using the following syntax: model.geom().measure.selection.named() in Matlab Livelink does not actually return the edge length. It just returns the following but not the actual length of the edge. Dimension 1: Geometry Geometry; Domain 31 Is there a way to get the value of actual dimension into the matlab workspace? Thanks!
