Gravity and 2D axisymmetric horizontal flow
Hi folks.
A colleague and myself are having a discussion about Gravity Force in Comsol.
I have a feeling I have read somewhere that the gravity force is defined by default in 2D axisymmetric horizontal flow,
however my colleague disagrees with me.
So I was wondering if anyone can shed some light on the subject.
And If it isn't defined by default how do you define it in 2D axisymmetric horizontal flow to be perpendicular
to the flow?
Hope someone can help.
Cheers.
3 Replies Last Post Feb 27, 2012, 8:18 a.m. EST
Posted: 1 decade ago Jun 2, 2011, 3:16 p.m. EDT
a gravity force appears in COMSOL as a "body force" that applies a force density (per element) of "g_const*solid.rho" in units [N/m^3]. But it's not present "by default" you must add it explicitely.
In 2D-axi it's more restrictif, as you have only 1 direction possible: along the axis of symmetry (up or down along "z"). So you have no way to model a "horizontal" pipe w,r,t gravity in 2D axi, bacause in 2D axi that would represents a centrifugal force along the radial direction "r"
For me you have only 3D to correctly model a flow in a cylindrical horizontal pipe with gravity applied vertically
Hi a gravity force appears in COMSOL as a "body force" that applies a force density (per element) of "g_const*solid.rho" in units [N/m^3]. But it's not present "by default" you must add it explicitely. In 2D-axi it's more restrictif, as you have only 1 direction possible: along the axis of symmetry (up or down along "z"). So you have no way to model a "horizontal" pipe w,r,t gravity in 2D axi, bacause in 2D axi that would represents a centrifugal force along the radial direction "r" For me you have only 3D to correctly model a flow in a cylindrical horizontal pipe with gravity applied vertically -- Good luck Ivar
Posted: 1 decade ago Jun 2, 2011, 3:22 p.m. EDT
If there's a force per unit volume that applies perpendicularly to your actual pipe, then the situation is not axisymmetric.
Posted: 1 decade ago Feb 27, 2012, 8:18 a.m. EST
When using 4.2A the body force for gravity can be expressed as: -nits.rho*g, where rho is the temperature dependant density from a library material, and nits in the case is the None-IsoThermal Flow module.
However, this does not appear to work in 3.5A (which I still use also for a number of reasons).
How can I use library definitions of density (temperature dependance) in the body force in version 3.5A?
When using 4.2A the body force for gravity can be expressed as: -nits.rho*g, where rho is the temperature dependant density from a library material, and nits in the case is the None-IsoThermal Flow module. However, this does not appear to work in 3.5A (which I still use also for a number of reasons). How can I use library definitions of density (temperature dependance) in the body force in version 3.5A?
