How to extract the time value?
I set a stop condition for my model, and I want to get the time value when the stop condition is satisfied, this time value will be used in other place, how should I do?
5 Replies Last Post Jun 9, 2011, 2:27 a.m. EDT
Posted: 1 decade ago Jun 6, 2011, 11:05 a.m. EDT
if I understand you correctly, when the first simulation is over "t" is "jammed at the ending time, ready for next simulation, no ?
Hi if I understand you correctly, when the first simulation is over "t" is "jammed at the ending time, ready for next simulation, no ? -- Good luck Ivar
Posted: 1 decade ago Jun 6, 2011, 11:10 a.m. EDT
For the next simulation, how should I input the time range [ range( , , ) ]? the starting time is the ending time of the first simulation.
[QUOTE] Hi if I understand you correctly, when the first simulation is over "t" is "jammed at the ending time, ready for next simulation, no ? -- Good luck Ivar [/QUOTE] For the next simulation, how should I input the time range [ range( , , ) ]? the starting time is the ending time of the first simulation.
Posted: 1 decade ago Jun 7, 2011, 3:42 a.m. EDT
Good remark :)
There I'm stuck, try with "support"
Indeed an interesting and useful remark/need
Hi Good remark :) There I'm stuck, try with "support" Indeed an interesting and useful remark/need -- Good luck Ivar
Posted: 1 decade ago Jun 8, 2011, 9:41 a.m. EDT
Good remark :)
I have asked the comsol support, and they said: "this cannot be done in the current version of COMSOL. You
might have to manually set up the time range based on the information given from the first run."
[QUOTE] Hi Good remark :) There I'm stuck, try with "support" Indeed an interesting and useful remark/need -- Good luck Ivar [/QUOTE] I have asked the comsol support, and they said: "this cannot be done in the current version of COMSOL. You might have to manually set up the time range based on the information given from the first run."
Posted: 1 decade ago Jun 9, 2011, 2:27 a.m. EDT
but tehn I understand that this is possible in Matalb, then you can extract the time from the first run and initiate the second run like that. It's just not possible in the GUI, reasonnable I believe
Hi but tehn I understand that this is possible in Matalb, then you can extract the time from the first run and initiate the second run like that. It's just not possible in the GUI, reasonnable I believe -- Good luck Ivar
