Precision of presented values in post-processing
I have a 2D problem in V4.1, which investigates the deformation of a rectangle. In the geometry mode, the values shown on the y-axis have correct precision, but after solving the problem, in the results mode y-axis values are presented as:
0.001
0.001
0.000
0.000
rather than
0.00125
0.00100
0.00075
0.00050
How can I change the precision of the values in the post-processing?
Unfortunately I could not find any option in:
Results/Views/View 2D/Axis
nor in
Results/2D Plot Group/Surface/Deformation
nor in
Model 1/Definitions/View 1/Axis
Any help is appreciated.
Manuel
4 Replies Last Post Jun 21, 2011, 5:22 p.m. EDT
Posted: 1 decade ago Jun 9, 2011, 3:52 a.m. EDT
there is a "preference display number of digit" somewhere in v4 (I believe default is 4 digits)
and for Tables, you have an icon to toggle for full precision.
Indeed not all fields switch to "Scientiifc E notation)
Hi there is a "preference display number of digit" somewhere in v4 (I believe default is 4 digits) and for Tables, you have an icon to toggle for full precision. Indeed not all fields switch to "Scientiifc E notation) -- Good luck Ivar
Posted: 1 decade ago Jun 9, 2011, 12:19 p.m. EDT
Hi Ivar,
Thanks for your hint.
I changed the precision from Options/Preference/General/Precision and changed the Input Display Precision to a number greater than 4, but I did not see any change in the output.
Also, I tried 2D plots group/Surface/Expression/Unit and played with the units, but it only affected the color bar not the values on the axes.
Manuel
Hi Ivar, Thanks for your hint. I changed the precision from Options/Preference/General/Precision and changed the Input Display Precision to a number greater than 4, but I did not see any change in the output. Also, I tried 2D plots group/Surface/Expression/Unit and played with the units, but it only affected the color bar not the values on the axes. Thanks Manuel
Posted: 1 decade ago Jun 10, 2011, 1:51 a.m. EDT
Then I have no other ideas, perhaps worth to send a suggestion to "support"
Hi Then I have no other ideas, perhaps worth to send a suggestion to "support" -- Good luck Ivar
Posted: 1 decade ago Jun 21, 2011, 5:22 p.m. EDT
Hi Ivar,
I guess there was a bug in V4.1 that didn't let me get the correct precision for this particular problem. I just installed V4.2 and the problem Is gone.
Thanks again.
JW.
Hi Ivar, I guess there was a bug in V4.1 that didn't let me get the correct precision for this particular problem. I just installed V4.2 and the problem Is gone. Thanks again. JW.
