Unable to call the local function defined when defining material properties
Posted Jul 26, 2018, 5:39 p.m. EDT Heat Transfer & Phase Change, Heat Transfer, Parameters, Variables, & Functions Version 5.3 2 Replies
I am new to COMSOL, and I ran into problems when I am defining material properties. I defined analytic functions and piecewise functions under Component 1 ==> Definitions, and then while I am trying to define the properties, I put the name of the function that I have already defined in the Expression box, but a floating box with "Unknow variable" appears everytime. And I also tried right click on Basic ==> Funcitions to define the variable that I would like to use as the property expression but the same thing happens.
I really would like to know why all the variable that I defined as functions cannot be called later on. But I have to define them as functions because they are temperature dependent and I have to put "if" condition for them because the expression is different under different temperatures.
I would appreciate any help! Thank you very much!
Best regards, Shengyue Shan
