Is possible to simulated the arc discharge temperature?
Juan Andrés Alfaro Barrantes
Hi! I want to know if there is possible to simulate an arc discharge on air? I'm interested only in the temperature generated.Thanks
5 Replies Last Post May 23, 2015, 9:33 a.m. EDT
Posted: 1 decade ago Jun 14, 2011, 12:45 a.m. EDT
I understand that as part of the "plasma" module, so in plain COMSOL you must add the equations yourself
Hi I understand that as part of the "plasma" module, so in plain COMSOL you must add the equations yourself -- Good luck Ivar
Posted: 1 decade ago Mar 28, 2012, 4:00 a.m. EDT
I'm new here and I want to model the arc between two metal contacts when they are opening and your answer was interesting for me. could you please tel me which equation I have to inter and how can I insert moving mesh
regards,
Hi, I'm new here and I want to model the arc between two metal contacts when they are opening and your answer was interesting for me. could you please tel me which equation I have to inter and how can I insert moving mesh regards,
Posted: 1 decade ago May 28, 2012, 3:09 p.m. EDT
It could possible to simulate Arc-discharge with "Surface Chemistry" for two electrodes (-1bar to 1bar)?
Hello, It could possible to simulate Arc-discharge with "Surface Chemistry" for two electrodes (-1bar to 1bar)?
Posted: 1 decade ago Apr 24, 2013, 4:57 a.m. EDT
I want to model the arc between two metal contacts when they are opening and your answer was interesting for me. could you please sell your model to me and tell to which equation I have to inter and how can I insert moving mesh
regards,
Song
Hi, I want to model the arc between two metal contacts when they are opening and your answer was interesting for me. could you please sell your model to me and tell to which equation I have to inter and how can I insert moving mesh regards, Song
Posted: 9 years ago May 23, 2015, 9:33 a.m. EDT
regards,
Song
Song , Hello ;
I am also doing the same thing now , can you please contact me if you already done it ?
Regards ;
[QUOTE] Hi, I want to model the arc between two metal contacts when they are opening and your answer was interesting for me. could you please sell your model to me and tell to which equation I have to inter and how can I insert moving mesh regards, Song [/QUOTE] Song , Hello ; I am also doing the same thing now , can you please contact me if you already done it ? Regards ;
