problems with convection furnace
hi,
I'm modeling a convection furnace. the expected heating time is around 6 hours. At this point every ingot in the oven should have reached the temperature 608 degrees celsius.
in my model it is almost immediately . I have no idea what I'm doing wrong. Can someone please give me a hint.
1 Reply Last Post Jun 14, 2011, 4:36 p.m. EDT
Posted: 1 decade ago Jun 14, 2011, 4:36 p.m. EDT
there can be many things: I would rank (as first guess)
- general units errors
- geometrical diimension (if you import the model this might change the default units)
- bad BC, absolute value instead of "density"
- bad material parameter
- wrong default temperature
Try to load your initial conditions too, and see if these are correct
Hi there can be many things: I would rank (as first guess) - general units errors - geometrical diimension (if you import the model this might change the default units) - bad BC, absolute value instead of "density" - bad material parameter - wrong default temperature ... Try to load your initial conditions too, and see if these are correct -- Good luck Ivar
