Hello J Yuan
Jul 26, 2011, 11:23 a.m. EDT
It is possible. I have done it in version 4.2, coupling linear elastic with transient Darcy's law. What I have done is tried to recreate the biot-poroelasticity example available in comsol model library. The results look more or less identical, but you may like to check. If you find mistakes, you can let me know.
I did this in Earth sciences module. I don't have the structural mechanics module.
Hope this helps.
Suresh
Hope this helps.
Suresh
Jul 26, 2011, 12:42 p.m. EDT
thank you for you kindly replay, yes it is possible to use the biot proroelasticity in comsol library. but for my problem i have to rewrite the darcy's equation since my equation is different from darcy', so i use the PDE module to instead Darcy's law and coupling with linear elastic. and i have solved this problem in 2-D. but in the 3-D model i ofen have this erro:
Error:
the boundaries conditon and properties are same as the 2-D problems
Error:
7 years ago
May 15, 2017, 2:41 a.m. EDT
Hi Yuan
Have you solved the problem?
I also want to have a test of building the poroelastic problem from PDE equations.
Could you send me a mph file of simplest 2d example?
Thank you!
Zhang
Error:
Hi Yuan
Thank you!
Zhang
[QUOTE]
Error:
[/QUOTE]
7 years ago
May 15, 2017, 2:45 a.m. EDT
In Suresh's mph file, I didn't see the contribution of pore pressure to mechanical deformation.
It may lack something.
Yige
Hope this helps.
Suresh
Yige
[QUOTE]
Hope this helps.
Suresh
[/QUOTE]
7 years ago
May 15, 2017, 2:55 a.m. EDT
Oh, I am sorry.
I found the changes for pore pressure in Suresh's model, when I read the output report.
In the solid.S11, solid.S22, and solid.S33, there is a term of alpha*pf.
Hope this helps.
Suresh
Oh, I am sorry.
[QUOTE]
Hope this helps.
Suresh
[/QUOTE]
