Using the Interpolation Function to Pass Boundary Conditions
Posted Jul 19, 2011, 4:09 p.m. EDT Computational Fluid Dynamics (CFD), Microfluidics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.2 1 Reply
I am a new COMSOL user, and I was hoping to understand how to properly use the interpolation function to transfer boundary conditions between models. I am working on a microfluidic model which is too large to mesh and solve in a single step, and so I need to break the model into segments, solve them individually, and pass the solution values from the outlet of model 1 to the inlet of model 2. (etc.)
After creating a global interpolation function, I set the inlet velocity values of a second model (with the exact same geometric dimensions) to the outlet values exported from the first model. The model runs and solves, but the solution is unexpected for several reasons:
1) The average velocity over the outlet surface of model 1 is more than 1000x greater than the average velocity over the inlet surface of model 2.
2) The highest velocity magnitude for model 2 was in the lower left corner of the conduit, not centered as in model 1.
A very simple model and the data file used for interpolation are both attached (the excel file was saved as a tab-separated text file). The data file was creating by exporting the velocity data from the outlet surface of model 1.
Any advice would be tremendously appreciated.
Thank You!
Thank You!
1 Reply Last Post Jul 20, 2011, 1:37 p.m. EDT
