Jul 27, 2011, 11:03 p.m. EDT
I have the same problem! Any luck yet?
Sirisha
Sirisha
Jul 28, 2011, 4:55 a.m. EDT
Unfortunately not....
I tested it on a simpler geometry and it also caused some problems. When reducing the Reynolds number it's better and I get convergence in P2-P1, but that doesn't really solve the problem...
Let me know if you are more lucky than I !
Guillermo
Guillermo
Jul 28, 2011, 2:01 p.m. EDT
Based on version 4.2 manual, P2-P1 is recommended for creeping flows. I am still using version 4.1 but I refer to the new manual because it has more details than the old manual.
My problem is that, with P2-P1 elements and a direct solver, I am able to achieve convergence with a coarse mesh. However when I use P2-P1 elements and a direct solver with a finer mesh, then I am unable to achieve the convergence.
Also, when I use the coarse mesh, I am running it using the COMSOL GUI on my desktop but when I use the fine mesh, I use batch mode and run it on a server. Not sure if that is making a difference. I cannot run the fine mesh on the desktop because the problem needs more memory than what my desktop can provide.
I am hoping someone has an answer for this problem!
Sirisha
Sirisha
