Error: Unknown property: funcname
I have defined a MATLAB function which is called by COMSOL. I get an error message such as:
Undefined value found.
- Detail: Undefined value found in the equation residual vector.
There are 2128 degrees of freedom giving NaN/Inf in the vector for the variable mod1.solid.pw
at coordinates: (0.452,0), (0. 448,0), ….
In the meantime, when I try to get a Report from my model in Results/Report, I receive such an error:
Unknown Property
Property: funcname
I think I have properly implemented the MATLAB function (regardless of how it calculates the things for me, because I get the above error).
Does anyone know what this error means?
Jessica
1 Reply Last Post Feb 12, 2013, 9:04 a.m. EST
Hello Jessica
Posted: 1 decade ago Feb 12, 2013, 9:04 a.m. EST
Hi I met the same problem
Unknown Property
Property: funcname When I try to produce a report.
Have you found an reason and solution for the problem ?
Thank you
Hi I met the same problem Unknown Property Property: funcname When I try to produce a report. Have you found an reason and solution for the problem ? Thank you
