Missing the top menu in Linux Ubuntu 11.04
Hi !
After installing 4.2 on Linux Ubuntu 11.04 the top menu with the "File", etc command is missing. I have it in every other program I'm using, but not in Comsol.
I'm kind of "a noob" in Linux so sorry if this is an "easy-fix" one.
regards and thanks
Nils Eivind
3 Replies Last Post Sep 30, 2011, 7:26 a.m. EDT
Chandramohan Somayaji
Posted: 1 decade ago Sep 30, 2011, 5:42 a.m. EDT
same issue here. Anybody with a solution?
Posted: 1 decade ago Sep 30, 2011, 7:08 a.m. EDT
Maybe it is a bug with the new Ubuntu. Normally Ubuntu displays all Menu Settings not in the same window but on the upper bar. Did you already tried the key options (Alt + F etc...)?
Cheers
Daniel
Maybe it is a bug with the new Ubuntu. Normally Ubuntu displays all Menu Settings not in the same window but on the upper bar. Did you already tried the key options (Alt + F etc...)? Cheers Daniel
Posted: 1 decade ago Sep 30, 2011, 7:26 a.m. EDT
It looks like a bug in ubuntu 11.04. Now, When I restart the computer with Ubuntu classic settings, everything
seems to work.!!! thanks for the info
Cheers
Daniel
It looks like a bug in ubuntu 11.04. Now, When I restart the computer with Ubuntu classic settings, everything seems to work.!!! thanks for the info [QUOTE] Maybe it is a bug with the new Ubuntu. Normally Ubuntu displays all Menu Settings not in the same window but on the upper bar. Did you already tried the key options (Alt + F etc...)? Cheers Daniel [/QUOTE]
