Dave Greve
Certified Consultant
6 years ago
Dec 20, 2018, 10:49 a.m. EST
The mf.Lcoil and related values are available in sinusoidal steady state (frequency domain) analysis.
Do you have a reason for NOT using frequency domain analysis??
D.W. Greve
DWGreve Consulting
D.W. Greve
DWGreve Consulting
6 years ago
Dec 21, 2018, 2:17 a.m. EST
Updated:
6 years ago
Dec 21, 2018, 2:21 a.m. EST
D.W. Greve
DWGreve Consulting
Thanks for your comment Mr D.W.Greve
I have simulated the coil moving uniformly along a defective magnetic conductor ( by using Moving Mesh (ale) ),try to find the connection between speed and inductance of coil.
I want to know if i can calculate the inductance of coil by 'mf.Vcoil'(Voltage of coil).
Thank you.
>D.W. Greve
>DWGreve Consulting
Thank you.
Dave Greve
6 years ago
Dec 21, 2018, 1:16 p.m. EST
No, you can't.
You need to think about how the inductance is calculated in sinusoidal steady state (frequency domain).
A phasor current I is forced and the phasor voltage V is calculated. The impedance is modeled by a resistance in series with an inductance. So Y = I/V = jwL + R. The inductance is calculated from the imaginary part of I/V, resistance from the real part.
NONE of the quantities mf.Vcoil, mf.Lcoil, mf.Rcoil are defined in time dependent analysis. You DO have V(t) and I(t), neither of which is exactly a sinusoid.
No, you can't.
