Sep 15, 2011, 4:57 p.m. EDT
pls check why is it giving an error i have tried 1000 times also i have posted many times in the forum but no one replies to it ...i dnt knw y??? if possible pls take up this challenge or atleast gv sm positive feedback....
thanking u in anticipation..
No expert on either but a quick search in the forum on the error message leads to several threads that could be worth reading.
Maybe a sweep to ramp up BC could do the trick ?
Nils Eivind
[QUOTE]
[/QUOTE]
Nils Eivind
Sep 17, 2011, 7:54 p.m. EDT
(I changed the answer)
Sep 18, 2011, 10:03 a.m. EDT
I've reviewed your attached files and have the following comments.
In the ODEs there exists a variable V, which depends on the spatial coordinate x. Therefore the ODEs are the so-called distributed ODEs. You should use Distributed ODEs and DAEs node instead of Global ODEs and DAEs. This node does not exist in Comsol 4.0a. You need Comsol 4.2.
Andrzej
Andrzej
Sep 18, 2011, 10:37 a.m. EDT
thank you andrez i will try it....
