internal variable definition of boundary position
The shape of a boundary varies with time in my moving mesh model. I need to access (during the solution - not only in
the results) the coordinates of the boundary.
My model is axisymmetric so I need to know the internal variable representing boundary radius as a function of z.
thanks
David
1 Reply Last Post Sep 20, 2011, 1:12 a.m. EDT
Posted: 1 decade ago Sep 20, 2011, 1:12 a.m. EDT
if you select a boundary the valuesof u,v,w are the displacements, you can use them. But it might be easier via a coupling variable, check the doc.
Depending on the frame selected you have the positions as x,y,z or Xm,Ym,Zm too, againcheck the doc
Hi if you select a boundary the valuesof u,v,w are the displacements, you can use them. But it might be easier via a coupling variable, check the doc. Depending on the frame selected you have the positions as x,y,z or Xm,Ym,Zm too, againcheck the doc -- Good luck Ivar
