Step function in a time-dependent problem
Hello everyone,
I am trying to implement a step function in my time-dependent problem where I want to lower the temperature of a constant temperature boundary from 40°C to 20°C after 10min (600s) of running the model. However, I always get the error "Failed to find consistent initial values. Last time step is not converged." Running the model without the step function works.
The details of my step function are: Location 600, From 0, To 1. Implemented into the constant temperature boundary like this: T0 = 40 - (20*step1(t)) [degC]
Thanks for your help!
2 Replies Last Post Jan 17, 2019, 12:52 p.m. EST
Posted: 6 years ago Jan 15, 2019, 12:23 p.m. EST
Hi Marco,
you need to take care to smooth the step sufficiently and to make sure that the timestepping resolves the smoothed function. You may need to introduce manual time stepping for that.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Marco, you need to take care to smooth the step sufficiently and to make sure that the timestepping resolves the smoothed function. You may need to introduce manual time stepping for that. Cheers Edgar
Posted: 6 years ago Jan 17, 2019, 12:52 p.m. EST
Hi Edgar,
Thanks for your reply! How exactly do I implement the smoothing into my model?
Cheers Marco
Hi Edgar, Thanks for your reply! How exactly do I implement the smoothing into my model? Cheers Marco
