Heat source simulation
Posted Jan 16, 2019, 5:37 a.m. EST Heat Transfer & Phase Change, Results & Visualization Version 4.4 2 Replies
Hi, I'm a complete comsol newbie. I'm trying to run a simulation that seems to be quite simple yet somehow I keep getting errors upon computing (usually the error is "The Relative Residual (x) Is Greater Than The Relative Tolerance"). Basically I'm trying to get the temp on a simplified transformer model (which I'v imported from an .stp file if it matters), which consists of a ferrite core, copper windings and a surrounding block of air I've added, and calculate it based on known losses. I created a steady-state project with the heat transfer in solids physic. Each relevant component was assigned as a heat source with a total power of the given losses. I left all other settings as default. I also assigned each component with its material and added missing properties as instructed by the software. Your assistance would be highly appreciated as I keep feeling as if I'm missing some basic consepts, given the fact that I'm failing to do some things that seem quite trivial. I'm attaching my model here.
Thank you
