Welded contact pair
I am new to Comsol. Before Comsol, I was using midas NFX.
Contacts in NFX support welded, general, rough, etc. The welded type does not allow separation in vertical and horizontal direction. Shall I use rigid connector in Comsol for this kind of contact?
The general one allows vertical seperation and horizontal sliding. I guess this is contact-pair with fritiction.
Thanks in advance.
Cheers, Panson
2 Replies Last Post Feb 28, 2019, 3:17 a.m. EST
Posted: 6 years ago Feb 28, 2019, 2:27 a.m. EST
For 'welded' contact you use an Identity Pair, together with a Continuity condition in Solid Mechanics.
The Contact features are intended for general contact simulations with separation and sliding. You could however also abuse the adhesion functionality in Contact to simulate a 'welded' state. That would essentially mean that you enforce the connection between the two parts using a penalty formulation, rather than by explicit pointwise constraints.
Henrik
Henrik Sönnerlind
COMSOL
Hi, For 'welded' contact you use an Identity Pair, together with a Continuity condition in Solid Mechanics. The Contact features are intended for general contact simulations with separation and sliding. You could however also abuse the adhesion functionality in Contact to simulate a 'welded' state. That would essentially mean that you enforce the connection between the two parts using a penalty formulation, rather than by explicit pointwise constraints. Regards, Henrik
Posted: 6 years ago Feb 28, 2019, 3:17 a.m. EST
Thank you Henrik.
Thank you Henrik.
