Marangoni Convection on a surface
Posted Oct 4, 2011, 5:30 p.m. EDT Wave Optics, Heat Transfer & Phase Change, Studies & Solvers 3 Replies
i am trying to simulate the Marangoni convection on the surface of a metal sheet, which is heated by a laser. The model is threedimensional and the Incompressible Navier-Stokes and the Convection and Conduction modules are used in a stationary analysis in COMSOL 3.5.
According to the "Marangoni Convection" guidance in the model library the surface tension is modeled by a PDE Mode Weak Form, but in 3D.
In 2D the equation in the weak form is: lm_test*(eta1*uy-gamma*Tx)+u_test*lm
For the 3D Model i tried it with 2 dependent variables lm1 and lm2 for the surface tension in the XY-plane in this way:
lm1_test*(eta1*uz-gamma*Tx)+u_test*lm1
lm2_test*(eta1*vz-gamma*Ty)+v_test*lm2
Unfortunately it is not possible to find a solution. I suppose the problem deals with the boundary conditions. In the 2D model the Dirichlet Boundary Condition is omitted at the vertex between the boundary with surface tension and the boundary with fixed temperature by changing the equation system: (s<1)*(T0_cc-T)
How can i adapt this to the 3D model? I tried (z<0.02)*(T0_cc-T), but it doesn't work.
What other problems should cause the problem?
Best regards and thanking you in anticipation,
Clemens
Clemens
3 Replies Last Post Oct 7, 2011, 9:52 a.m. EDT
