Radially Poled Piezoelectric Cylinder
Posted Oct 11, 2011, 10:32 a.m. EDT MEMS & Nanotechnology, Piezoelectric Devices, Acoustics & Vibrations, Mesh, Structural Mechanics 2 Replies
I am working on a problem with a radially poled hollow piezoelectric cylinder. I have successfully built this model in 2D axi but would like to also have a 3D model that works. Both models (so far) are attached. I am encountering two issues with this transition: meshing the thickness properly and defining the ceramic polarization coordinate system. Help with either issue would be appreciated. Details:
1) Increasing the Mesh density along the thickness. I'd like to get 3-5 elements (preferably quad's to decrease total # elements) meshed in the thickness direction since that is the direction of polarization. However, I don't need tons of elements along the height (maybe 10 or so), so a user-defined mesh makes sense in this case because I can't solve for even medium size models on my machine. I tried to do a mapped mesh but the problem is there is no "edge" to define a distribution on in the thickness direction. I also tried to made a line (bezier polygon) along the length just for meshing purposes but that failed because I got an "isolated entites found." message. I reverted to the "full auto" mesh just to have it solve something.
2) The piezoelectric materials (in the material browser or in general for piezo materials) are defined in a cartesian (x1,x2,x3) manner, with x3 being the direction of polarization. I need the ceramic to be poled in the radial direction as it is in the 2D zxisymmetric model. I can define and apply a cylindrical material coordinate system but that still doesn't fully solve the issue because (x3) is still the Z direction so it thinks it's poled along the height even though the electrodes are applied at the inner and outer surfaces. How can I define the radial direction in 3D as the polarization direction?
Thanks!
Hello Marc
