Electrodeposition Problems at edges
I am trying to model electrodeposition of copper on an angled part, but at the edges where the part is masked the mesh goes crazy. I can get it to work by chopping off the edges, but the edges is where all the interesting stuff happens. I have tried remeshing but it just goes crazy (see attached images) Does anyone have a solution to this problem?
2 Replies Last Post Oct 20, 2011, 1:47 p.m. EDT
Posted: 1 decade ago Oct 19, 2011, 1:29 a.m. EDT
as you say the interesting things happen at the angles, I expect that is why COMSOL is meshing very dense. Normally it's the "Resolution of curvature" parameter in the "Size" tab that looks after this, in conjunction with the other parameters. Take a look at the mesh chapter in the doc. Probably there is a specific one for the ElectroDepos one too.
It takes some time to understand all the buttons in COMSOL, but if you play a little with a simple cube (with 4 rounded off angles, use a work plane, square, fillet and extrude), you quickly can get the grasp of the different parameters, but it's worth the time and effort ;)
Hi as you say the interesting things happen at the angles, I expect that is why COMSOL is meshing very dense. Normally it's the "Resolution of curvature" parameter in the "Size" tab that looks after this, in conjunction with the other parameters. Take a look at the mesh chapter in the doc. Probably there is a specific one for the ElectroDepos one too. It takes some time to understand all the buttons in COMSOL, but if you play a little with a simple cube (with 4 rounded off angles, use a work plane, square, fillet and extrude), you quickly can get the grasp of the different parameters, but it's worth the time and effort ;) -- Good luck Ivar
Posted: 1 decade ago Oct 20, 2011, 1:47 p.m. EDT
I have played with the parameters a lot, but I think what I need is the ability to remesh, if the mesh only advances normal to the original surface the deposit will never be correct. However, when I remesh it looks completely different from the previous solution. I have tried remeshing shapes with a smoother surface and it works just fine, but I can't get it to work for a more irregular surface. Any suggestions?
