                                Oct 19, 2011, 10:32 a.m. EDT
first remark, be careful with the naming, test() is normally an internally defined COMSOL operator (used in the weak expressions) so pls choose another name to be sure there is no collision there
But then I do not understand your question, you can select in the plot node all items for a time series, or only a few or interpolated ones, see the doc on the higher level plot node
                                Oct 19, 2011, 10:51 a.m. EDT
thanks for the hint with the naming.
My question concerns the following problem. I want to know the residual between a defined interpolation function, e.g. experiment() as interpolation of some measured data from a diffusion experiment and the results of the simulation, but i want the the residuals only at the experimental time points. It's the residual between the experimental and simulated diffusive flux, so I thougt of something like (experiment(t=20,30,40)-(-D*ux(t=20,30,40)))^2
Johannes
Johannes
                                Oct 19, 2011, 1:14 p.m. EDT
not sure what to propose, that needs some thinking ;)
By defaut, if you are driving your simulation by the difference of the experimantal to the calulcated points, it would take the residual of the interpolated values, at least that is how I understand COMSOL's default behaviour
