Is there any model about anchor damping in COMSOL?
Hi everyone
I am a beginner in COMSOL and I want to calculte the anchor-loss-limited Q in MEMS resonator (square plate resonator which has four anchors at its four corners). I think the perfectly matched layers (PMLs) should be used to absorp the outgoing elastic energy. Could anyone share a model about anchor damping? Thanks.
James
4 Replies Last Post Mar 27, 2012, 6:26 a.m. EDT
Hello James
Posted: 1 decade ago Mar 16, 2012, 1:20 p.m. EDT
Hi James,
You can refer to the attached paper. In this paper, the material properties that you can enter for the Matched Layer is mentioned.:
Good luck,
Amir
Hi James, You can refer to the attached paper. In this paper, the material properties that you can enter for the Matched Layer is mentioned.: Good luck, Amir
Posted: 1 decade ago Mar 20, 2012, 8:00 a.m. EDT
Hi James,
Good luck,
Amir
Hi Amir
Thanks for your help. I have one question for this paper. Do you know how to calculate the attenuation constant alpha? The author of this paper sets it to 3 but gives no reason.
James
[QUOTE] Hi James, You can refer to the attached paper. In this paper, the material properties that you can enter for the Matched Layer is mentioned.: Good luck, Amir [/QUOTE] Hi Amir Thanks for your help. I have one question for this paper. Do you know how to calculate the attenuation constant alpha? The author of this paper sets it to 3 but gives no reason. Regards, James
Posted: 1 decade ago Mar 26, 2012, 5:22 p.m. EDT
James:
I think you have figure that out by yourself. It is geometry dependent and for high Q-factors you require a different a than 3. Play with mesh size and a and see when your result converges.
Cheers,
Hadi
James: I think you have figure that out by yourself. It is geometry dependent and for high Q-factors you require a different a than 3. Play with mesh size and a and see when your result converges. Cheers, Hadi
Posted: 1 decade ago Mar 27, 2012, 6:26 a.m. EDT
Can you guys tell me how to calculate Q-factor using Eigen frequency analysis? Basically I have cantilever beam, but I do not how to calculate Q-factor.
Sankha
Hello, Can you guys tell me how to calculate Q-factor using Eigen frequency analysis? Basically I have cantilever beam, but I do not how to calculate Q-factor. Thanks Sankha
