Maximum value from each slice of cut planes
I'm simulating air flow through a tube and looking at difference in presure along the system. I want to graph the maximum pressure along different areas of the system. To do this, I would like to find the maximum value of cut planes along the system. I have only found a way to find a single maximum but not each maximum for each slice. Anyone have advice?
Thanks!
1 Reply Last Post May 20, 2019, 4:53 a.m. EDT
Michael Rembe Certified Consultant
Posted: 6 years ago May 20, 2019, 4:53 a.m. EDT
Hi Joseph, define each cut plane as seperate data set (data sets -> cut plane). Add this number of cut planes to your plot, each cut plane one data set. Then add this number of min/max surfaces to you plot and chose the seperate cut plane data sets. In this way you can realize maximum values of each cut plane.
Best regards Michael Rembe
Michael Rembe
Rembe Consulting PartG mbB
www.rembe-consulting.de
Hi Joseph, define each cut plane as seperate data set (data sets -> cut plane). Add this number of cut planes to your plot, each cut plane one data set. Then add this number of min/max surfaces to you plot and chose the seperate cut plane data sets. In this way you can realize maximum values of each cut plane. Best regards Michael Rembe
