Matlab post-processing of multi-steps simulations
I have carried out multi-steps simulations using comsol GUI in 1-D PDE mode. By "multi-steps" I mean that I have set up several solvers running one after the other. (Solver 1 is from time = 0 to time = 1 ; solver 2 is from time = 1 to time =2 using solver 1 results as initial conditions).
Once the simulation is done, i load the mph file in matlab using :
model=mphload('myfile.mph');
Then i want to acces to the value of my variable by :
u=mphinterp(model,'u', 'coord', ... , 'T', ...)
If i set 'T' to linspace(0,1,n), I can obtain the results given by solver 1 but if I set 'T' to linspace(1,2,n) the interpolation can't be done.
Do you have any idea to interpolate the results given by solver 2?
Thanks !
1 Reply Last Post Nov 4, 2011, 9:47 a.m. EDT
Posted: 1 decade ago Nov 4, 2011, 9:47 a.m. EDT
Solutions from different solvers end up in different datasets.
You must specify the name of the dataset in the call to mphinterp.
Lars Gregersen
Comsol Denmark
Hi Solutions from different solvers end up in different datasets. You must specify the name of the dataset in the call to mphinterp. -- Lars Gregersen Comsol Denmark
