Stop sweep when a probe value decreases
Hi all,
I was introduced to the "stop condition" in parametric sweeps (see attached). Is it possible to make a sweep stop when a probe value for the new solution is smaller than that from the preveous solution?
Thanks, Jacob
2 Replies Last Post Jun 11, 2019, 9:23 a.m. EDT
Thure Ralfs COMSOL Employee
Posted: 5 years ago Jun 11, 2019, 8:55 a.m. EDT
Updated: 5 years ago Jun 11, 2019, 8:55 a.m. EDT
Hi Jacob
If I understand you question correct then, yes you can. You can see a very simple example in the attached model. I use a Global ODE to store “Tnew” in a new dependent variable “Told” and to make “Told” the previous solution I add a “Previous Solution” node under the parametric solver step (same place as you “Stop condition”.
Best regards Thure
Hi Jacob If I understand you question correct then, yes you can. You can see a very simple example in the attached model. I use a Global ODE to store “Tnew” in a new dependent variable “Told” and to make “Told” the previous solution I add a “Previous Solution” node under the parametric solver step (same place as you “Stop condition”. Best regards Thure
Posted: 5 years ago Jun 11, 2019, 9:23 a.m. EDT
Hi Thure,
Thanks for your reply! That works for me!
Best, Jacob
Hi Thure, Thanks for your reply! That works for me! Best, Jacob
