Lars Gregersen
COMSOL Employee
5 years ago
Jun 17, 2019, 4:58 a.m. EDT
Updated:
5 years ago
Jun 17, 2019, 4:57 a.m. EDT
Hi Ehsan
Yes, if you are using a MATLAB node in your Comsol model your function must be able to take arguments that are vectors of equal size and your function must return a vector of the same size as the inputs. You can test this using the Matlab command by passing vectors that you hace created yourself.
The reason is that each call to Matlab are rather slow and hence we need to batch the calls to speed things up.
You can insert a stop condition in your solver setup. The conditions used for stopping can depend on a Matlab function (and any other valid Comsol expression/function).
Lars Gregersen
Comsol Denmark
Hi Ehsan
5 years ago
Jun 20, 2019, 6:27 a.m. EDT
Updated:
5 years ago
Jun 20, 2019, 6:29 a.m. EDT
Hi Ehsan
Thank you for your attention!
I face with a problem. In fact, I wanna use this function as a stop condition.
this is my Matlab function:
function MI = MixingIndex(c)
sumc=0;
cavg=0;
for i=1:length(c)
cavg= cavg+c(i);
end
cavg=(cavg/length(c));
for n=1: length(c)
a=(((c(n)-cavg/cavg)^2));
sumc=sumc+a;
end
MIpre=(1-sqrt((1/length(c))sumc))100;
X = zeros(1,length(c))
for i=1:length(c)
X(i)=MIpre
end
MI=X;
model.func.create('extm1', 'MATLAB');
model.func('extm1').setIndex('funcs', 'MixingIndex', 0, 0);
model.func('extm1').setIndex('funcs', 'ehs', 0, 1);
model.component('comp1').variable.create('var1');
model.component('comp1').variable('var1').selection.geom('geom1', 2);
model.component('comp1').variable('var1').selection.named('geom1_cad1_Face06Part8_bnd');
model.component('comp1').variable('var1').set('c_outlet', 'c');
model.component('comp1').probe.create('bnd1', 'Boundary');
model.component('comp1').probe('bnd1').set('intsurface', true);
model.component('comp1').probe('bnd1').selection.named('geom1_cad1_Face06Part8_bnd');
model.component('comp1').probe('bnd1').set('expr', 'MixingIndex(comp1.c_outlet[m^3/mol])');
model.component('comp1').probe.create('var1', 'GlobalVariable');
model.component('comp1').probe('var1').set('expr', '');
model.component('comp1').probe.remove('var1');
model.component('comp1').probe('var1').set('expr', 'if(comp1.bnd1>1,(at(t,comp1.bnd1)-at(t-timestep,comp1.bnd1))/timestep,10[1/s])');
model.sol('sol1').feature('t1').create('st1', 'StopCondition');
model.sol('sol1').feature('t1').feature('st1').setIndex('stopcondarr', '', 0);
model.sol('sol1').feature('t1').feature('st1').setIndex('stopcondterminateon', 'true', 0);
model.sol('sol1').feature('t1').feature('st1').setIndex('stopcondActive', true, 0);
model.sol('sol1').feature('t1').feature('st1').setIndex('stopconddesc', 'Stop expression 1', 0);
model.sol('sol1').feature('t1').feature('st1').setIndex('stopcondarr', 'comp1.var1<=0.2', 0);
%%%%%%% but the error is "could not evaluate stop condition %%%%%%%%
although all of the variables and probes evaluate during solution, It seems the stop condition could not access to the variable in previous time step!
what is your idea and suggestion?
>Hi Ehsan
sumc=0;
cavg=0;
for i=1:length(c)
cavg= cavg+c(i);
end
for n=1: length(c)
sumc=sumc+a;
end
MIpre=(1-sqrt((1/length(c))*sumc))*100;
for i=1:length(c)
X(i)=MIpre
end
MI=X;
