Posted Nov 10, 2011, 5:05 p.m. EST Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.1 2 Replies
I was doing a simulation about coupling two physics together by using the moving mesh. What I did is to run the solid mechanics first and stored the results. The laminar flow was then run by using the output from solid mechanics as the input. However, the solid mechanics part was fine but once I did laminar flow a error window was popped up.
Singular matrix.
There are 113 void equations (empty rows in matrix) for the variable Pump.p
at coordinates: (0.0145358,-0.0073668,0.001425), (0.0137255,-0.00590277,0.001425), (0.0124142,-0.0068996,0.001125), (0.0122855,-0.00665798,0.001125), (0.0122064,-0.00664936,0.001425), ...
There are 1074 degrees of freedom that do not occur in any equation (empty columns in matrix) for the variable Pump.p
There was no errors relative to the moving mesh part so I supposed this part was okay. The problem might be the coupling between two physics.....
Anyone knows what happened?
Many thank for the help.
Singular matrix.
2 Replies Last Post Nov 12, 2011, 5:19 a.m. EST
