2 decades ago
Jan 2, 2010, 4:05 a.m. EST
CAnnot tell like that, but you have a clue by the "subdomain 40" indication, identify the subdomain 40 and see how it looks, it could be that it's touching or is adjacent to a couple of meshed items, and then perhaps the algorithm does not manage to fit all the adjacent meshes.
Hope it helps
Hope it helps
2 decades ago
Jan 2, 2010, 8:15 a.m. EST
Hi Ivar,
its exactly as you say. The domain I've been trying to mesh is adjacent to meshed subdomains. Some are made by simple extrusion, some by extrusion with twist, ergo their resulting swept meshes cant match on sides. I missed that. Is there a chance to get over this ? For example is there a chance to create a special face in the model where 3D meshes, which are not compatible because of the shape of their elements, could be adjacent to this face(2D) without any problem? Some kind of face which would perform the interpolation from one 3D mesh to another ? Some kind of mesh-independent continuity of solution ?
Hi Ivar,
2 decades ago
Jan 2, 2010, 12:41 p.m. EST
A difficult case I believe, as quad mesh do not mix with tets. One way could be to mesh all parts possible, then transform everything to tets and try a free mesh on the reminding. Or try to mesh all edges remainig in a regular way, and then the volumes
2 decades ago
Jan 4, 2010, 1:27 p.m. EST
yea. I also thought about changing the swetp mesh elements to tets and than meshing the rest with free, but unfortunatelly my case is the small induction machine(the one we can meaure in our lab) and it has so small air gap(the critical area between the straight and twisted 2D->3D geometry extrusion meshed with sweep mesh - stator, rotor respetivelly) that the free mesh algorythm fails anyway(and if it made it, it would probably produce extremly low quality elements). So im gonna have to go with free mesh on whole geometry, which results in 2e6 DOFS :(
anyway, thanks x 1000 for your time
Hans
Hans
2 decades ago
Jan 5, 2010, 2:24 a.m. EST
Then my only recommendation is to try to simplify via symmetry, it's complicates, and one cannot do everything, but still, it gives results that with a little tweaking can mostly be extrapolated, FEM is in no way exact, I say always to some 10% precision only
2 decades ago
Jan 5, 2010, 9:07 a.m. EST
I have spent some time thinking about simplifying the geometry, but then I found out that the best way is to leave the geometry unchanged (mainly arcs) and leave it to comsol. There are many arcs in my geometry and still the best way to deal with them is to leave it up to comsol. When meshig, COMSOL changes smooth arcs to straight, flat faces in an impressively smart way. Resulting mesh is less complicated than when I change arcs to straight shapes in geometry stage by hand. Unfortunatelly removing other geometry features would result in too rough approximation.
Hans
Hans
2 decades ago
Feb 2, 2010, 11:55 a.m. EST
Im stupid, I could have used the assembly to prevent the mesh compatibility problems.
