How to set the initial guess not from my previous solution?
Posted Nov 18, 2011, 5:14 a.m. EST Studies & Solvers Version 4.2 1 Reply
For a frequency domain analysis, I encounter a problem that is
when I do the analysis at each single frequency, then I can get a accurate result,
but if I analyze a certain range of frequency i.e. range(10,10,1000), the solver will take a long time around certain frequency, and get quite a large error around these frequency and hardly to converge.
Comsol support told me that is because the result changes a lot around these frequencies, and the default set for comsol is to use the previous solution as the next solver's initial guess, therefore, around these frequencies, it's hardly to get the result based on the previous solution guess.
so my question is how could I change the solver that it won't use the previous result as the initial guess, how can I make the analysis (for a range of frequency i.e range(10, 10, 1000)) just like I only do one frequency analysis per time?
Thanks for any hints or guides!!
best regards,
Hsuan
best regards,
Hsuan
1 Reply Last Post Nov 18, 2011, 7:09 a.m. EST
