Domain Plot
My 3D model is consisted of 3 domains
and i want to plot the temperature at domain 1 only.
Can you help?
2 Replies Last Post Nov 20, 2011, 8:40 a.m. EST
Posted: 1 decade ago Nov 20, 2011, 2:45 a.m. EST
you have at least two ways ;)
1) you add a filter sub-node to your plot and you use the Boolean expression "dom ==1" or "dom==2" for domain 1, respectively 2 ...
2) you right click the data set, you duplicate your data set and then add a filter to the snd data set
Hi you have at least two ways ;) 1) you add a filter sub-node to your plot and you use the Boolean expression "dom ==1" or "dom==2" for domain 1, respectively 2 ... 2) you right click the data set, you duplicate your data set and then add a filter to the snd data set -- Good luck Ivar
Posted: 1 decade ago Nov 20, 2011, 8:40 a.m. EST
Thanks!
I solve the problem :)
Thanks! I solve the problem :)
