Not able to select Geometry in Solid Mechanics
Sanjay Mukuntha Madhava
I have a circular Membrane supported by 4 beams, however i am not able to select the circular membrane to apply tensile stress and boundary load. The message that i get is "(Not Applicable)".
Can someone please help me with this
Thanks in advance
Regards
Sanjay
1 Reply Last Post Nov 29, 2011, 2:18 a.m. EST
Posted: 1 decade ago Nov 29, 2011, 2:18 a.m. EST
because it s not included in the main Solid physics node, select all domains in the main physics node and you are back to work ;)
Hi because it s not included in the main Solid physics node, select all domains in the main physics node and you are back to work ;) -- Good luck Ivar
