Client/Server, Parametric sweep, "Export to File" problem
I am running Comsol in a Client/Server mode. The server is running on Linux, the Client on Windows. I use a parametric sweep. For each iteration of the parametric sweep, I want that the *.mph file be saved, as well as several graphs/data. I therefore use the nodes "Save Model to File" and "Export to file" in my parametric sweep.
Although my client is running on Windows, I found out that I have to set the path for saving the *.mph file on the linux server. After each iteration of my parametric sweep, a *.mph file is created on the linux server.
I added the node "Export to File" in order to save additional graphs/data at each itreation. I set the filename to a location on the linux machine. It did not work. I got the following error message after the first iteration, i.e., the first time when the node "Export to File" comes into play:
"Error in sweep: Unknown property. -Property: filename."
I then changed the filename to a location on the Windows machine. This resulted in the same error message.
The problem is described in a more visual way in the attached pdf. Does anyone know what to do?
Thanks a lot. Alois
2 Replies Last Post Dec 2, 2011, 8:11 a.m. EST
Posted: 1 decade ago Nov 30, 2011, 2:29 p.m. EST
I'm astonished that this hybrid solution works, and I'm not sure it was foreseen like that, so I believe the best and most complete reply would come from "support". Anyhow pls report back, Ifind it's of general interest
Hi I'm astonished that this hybrid solution works, and I'm not sure it was foreseen like that, so I believe the best and most complete reply would come from "support". Anyhow pls report back, Ifind it's of general interest -- Good luck Ivar
Posted: 1 decade ago Dec 2, 2011, 8:11 a.m. EST
Dear Alois,
I can confirm that this is a problem in COMSOL 4.2a; the filename issue occurs when using export to file on an animation node or player node in Export. We will add support for transferring the files from the server to the client in client/server mode. Fixes for these issues are scheduled for COMSOL 4.3.
With best regards,
Anders Ekerot
COMSOL Support
Dear Alois, I can confirm that this is a problem in COMSOL 4.2a; the filename issue occurs when using export to file on an animation node or player node in Export. We will add support for transferring the files from the server to the client in client/server mode. Fixes for these issues are scheduled for COMSOL 4.3. With best regards, Anders Ekerot COMSOL Support
