COMSOL 4.2a with MATLAB (COMSOL 3.5a compatibility) error
Hi, I'm trying to use COMSOL 4.2a with MATLAB (COMSOL 3.5a compatibility) and I obtained the following error:
Undefined variable "com" or class "com.femlab.jni.FlNativeUtil.ensureLibIsLoaded".
Error in initcomsol (line 105)
com.femlab.jni.FlNativeUtil.ensureLibIsLoaded();
And for example when I type fem.geom=circ2, this is the error:
Undefined variable "com" or class "com.femlab.util.Prop".
Can anybody help me?
Thanks.
3 Replies Last Post Mar 26, 2013, 10:32 p.m. EDT
Hello Yenny Pinto
Posted: 1 decade ago Feb 24, 2012, 1:41 p.m. EST
Hi Yenny,
I have the same problem,
Could you help me?
Thanks in advance
Hi Yenny, I have the same problem, Could you help me? Thanks in advance
Posted: 1 decade ago May 27, 2012, 3:38 p.m. EDT
I too have the same problem if anyone comes across a solution. I'm using Matlab R2012a and Comsol 4.2a & 3.5a patched to the latest versions.
I've found that if I start Matlab from Comsol 3.5a, rather than 4.2a (with Comsol 3.5a Compatibility) then everything works fine.
Cheers,
Andrew
Hi, I too have the same problem if anyone comes across a solution. I'm using Matlab R2012a and Comsol 4.2a & 3.5a patched to the latest versions. I've found that if I start Matlab from Comsol 3.5a, rather than 4.2a (with Comsol 3.5a Compatibility) then everything works fine. Cheers, Andrew
Posted: 1 decade ago Mar 26, 2013, 10:32 p.m. EDT
hi,
I also have the same problem, I am using matlab2010a with comsol4.2a, but COMSOL 3.5a compatibility mode has same error as discribed above.
I want to ask what do you mean of 'if I start Matlab from Comsol 3.5a, rather than 4.2a (with Comsol 3.5a Compatibility)then everything works fine '??
matlab from Comsol 3.5a will automaticlly connect with Comsol 3.5a, does it possible to connect with 4.2a? how to do that?
hope you can see my message
thank you
hi, I also have the same problem, I am using matlab2010a with comsol4.2a, but COMSOL 3.5a compatibility mode has same error as discribed above. I want to ask what do you mean of 'if I start Matlab from Comsol 3.5a, rather than 4.2a (with Comsol 3.5a Compatibility)then everything works fine '?? matlab from Comsol 3.5a will automaticlly connect with Comsol 3.5a, does it possible to connect with 4.2a? how to do that? hope you can see my message thank you
