Dec 9, 2011, 1:02 a.m. EST
in V4 you have the "vue" for the active properties, and then you need to go through the equations in detail to see where and when some are used (tedious) mostly the doc covers this too, but the info is scattered around ;)
Magnus Ringh
COMSOL Employee
Dec 9, 2011, 3:07 a.m. EST
The reference resistivity rho0 is used for exactly the linearized resistivity sigma = 1/rho0*(1+alpha*DeltaT) that you mention, which is a predefined option ("Linearized resistivity") in the Current Conservation settings for the Electric Currents interface.
In the Copper node under Materials (and any other materials that you use), green check marks indicate the material properties that are used by the physics interfaces in the model. So, in an Electric Currents model, if you use "From material" to specify the electrical conductivity, the following material properties are used:
Electrical conductivity sigma
Relative permittivity epsilonr (for the constitutive relation)
If you instead use "Linearized resistivity" to specify the electrical conductivity, the following material properties are used:
Reference resistivity rho0
Resistivity temperature coefficient alpha
Reference temperature Tref
Magnus Ringh, COMSOL
Dec 14, 2011, 9:01 a.m. EST
Thanks for the explanation. I find it sometimes really difficult to understand the implementation and where which input is used. Maybe a context related search function would help the user in such situations.
Jürgen
Jürgen
