COMSOL Unable to Compute Third Order Space Derivative
Hi, I have been working on a project which requires the evaluation of a third order space derivative term in my 1-D PDE, and this is done using the Coefficient Form PDE module. I found that COMSOL outputs the third order derivative d^3u/dx^3 as zero under the results plot.
I know this is clearly not the case since the plot of uxx clearly shows a curve and not a constant.
Since then I have search the internet regarding this issue and have tried other methods of specifying the derivative, including defining a new variable
F=uxx
and plotting d(F,x) in the results section still returns zero for all values of x.
I have also tried different order Langrange shape functions (up to septic) and yet the results are still the same. I am baffled by this as I even tested for a simple function such as
u(x)=4x^4 +3x^3-2x^2+x+7
and I am still unable to obtain the third order space derivative under Results.
Any assistance on this issue would be greatly appreciated. Thank you
2 Replies Last Post Nov 24, 2019, 1:52 a.m. EST
Walter Frei COMSOL Employee
Posted: 5 years ago Nov 21, 2019, 3:25 p.m. EST
Updated: 5 years ago Nov 21, 2019, 10:26 a.m. EST
Hello, See: https://www.comsol.com/support/knowledgebase/816/
Posted: 5 years ago Nov 24, 2019, 1:52 a.m. EST
Hi, thank you for you guidance, I have managed to resolve my problem. It turns out instead of specifying F=uxx under the 'variables' section, I have to add another PDE field and specify F as its dependant variable, with F=uxx.
