Failed to run method
I am recording a method, then run that method to a similar file. The method is like this:
model.result("pg39").run();
model.result().dataset("dset1").createDeformedConfig("deform1", "mesh2");
model.component("comp1").geom("deform1").export("D:\matlab\y1file.mphbin");
when I run it, I got this error message:
Failed to run method.
Failed to create file. - File: D:\matlab\y1file.mphbin
It seems it failed to save the geometry as a file. Could anybody point out what should I do to solve this? Thank you.
Update: this is already solved. I just unset the"enforce seurity restrictions" in preferences. I cannot delete this question from this forum.
0 Replies Last Post Dec 14, 2019, 2:49 p.m. EST
Hello Eko Ilman
