Dec 16, 2011, 12:38 a.m. EST
i am not sure whether you can impose open boundary or not. you may check the document.
Dec 23, 2011, 5:02 a.m. EST
hi,
yes, using convective cooling. h for free convection about 5-25 W/m²K. Or there is also a formula how to evaluate h for horizontal cylinder on free convection.
h ~ Fluid.temperatur-outer cylinder.temperatur and Diameter
regards
akmal
hi,
regards
akmal
Nagi Elabbasi
Facebook Reality Labs
Dec 24, 2011, 1:30 p.m. EST
Infinite elements are not suitable for this type of CFD analysis. If you want to model the air flow around the pipe you need to model and mesh a suitably sized block of air. If your interest is only the heat loss resulting from the air flow you can avoid modeling the air and setup instead a convective boundary condition on the external pipe surfaces as Akmal suggested.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
Dec 27, 2011, 5:06 a.m. EST
Hi All,
i'm not CFD expert (never use special CFD simulation software). But as far as i know, comsol is enough to do CFD simulation. There are modules to simulate fluid flow. To simulate air flow around a pipe it can be easely done.
there is some example, google thermos_laminar_flow.mph.
Comsol mesh can also be adapted for fluid or non-fluid.
happy holiday
akmal
Hi All,
happy holiday
akmal
