Defining steady state results as a initial condition for trasient problem
I want to define the steady state results(temperature distribution) as a initial temperature distribution.
Is this possible and can you tell me how?
3 Replies Last Post Dec 20, 2011, 3:25 a.m. EST
Posted: 1 decade ago Dec 19, 2011, 3:30 a.m. EST
if you mean you have solved a steady state and saved the result (for dependent variable T), then you can write in "T" in the initial conditions, as "T" is a filed and its rather T(x,y,z) you are defining in this way, but the (x,y,z) is dropped by the COMSOL writing convention
Hi if you mean you have solved a steady state and saved the result (for dependent variable T), then you can write in "T" in the initial conditions, as "T" is a filed and its rather T(x,y,z) you are defining in this way, but the (x,y,z) is dropped by the COMSOL writing convention -- Good luck Ivar
Posted: 1 decade ago Dec 19, 2011, 11:36 a.m. EST
Dear, Ivar
Firstly, I greatly appreciate your fast reponse and that helped me.
1. You mean after solving the steady state solution for the first time, and save the results(study 1)
2. Then, add study 2 for transient case and write 'T' in the initial condition tab, right?
3. another question : if I want to solve the transient solution from the results not from 0 second but from
30 seconds, would you give me advice?
Dear, Ivar Firstly, I greatly appreciate your fast reponse and that helped me. 1. You mean after solving the steady state solution for the first time, and save the results(study 1) 2. Then, add study 2 for transient case and write 'T' in the initial condition tab, right? 3. another question : if I want to solve the transient solution from the results not from 0 second but from 30 seconds, would you give me advice? Thanks
Posted: 1 decade ago Dec 20, 2011, 3:25 a.m. EST
you can link the two solver steps by adding a stationary + a time series one after the other under the same main study node.
Now how to get to t=30[s] directly, not sure as it would strongly depend on your BCs, if these are cte or time dependent ..., you can in any case use different time steps and change several range() range() operators, provided the time is monotonously increasing
Hi you can link the two solver steps by adding a stationary + a time series one after the other under the same main study node. Now how to get to t=30[s] directly, not sure as it would strongly depend on your BCs, if these are cte or time dependent ..., you can in any case use different time steps and change several range() range() operators, provided the time is monotonously increasing -- Good luck Ivar
