Hi Sinéad
We don't test all Linux distributions so I can't tell if yours has a special problem. Upgrading to Comsol 5.5 may help.
Ways to circumvent your problem:
Instead of using mphlaunch you can do:
1) Start Comsol client using the command "comsol client"
2) Connect to the Comsol Multiphysics Server
3) When the GUI opens load the model from the server (File->COMSOL Multiphysics Server->Import Application from server
Your problem regarding mphopen is caused by this: Comsol Multiphysics Server is able to load more than one model at a time. The Comsol GUI is only able to have one model open at a time. When you have the same model open in Matlab and in the Comsol GUI at the same time you can open another model in Matlab (but the previously loaded model stays open in the Comsol GUI). Hence, when you change a parameter in the model you've just loaded it is not shown in the Comsol GUI because the two models are different.
You can read more about this in the LiveLink for Matlab User's Guide in the section titled "Managing The Comsol Model Object".
Lars Gregersen
Comsol Denmark
Hi Sinéad
