how to find heat loss in hollow cylinder???
Hi everyone,
Now i am using comsol 4.1. i have finished one Heat transfer problem (hollow cylinder) with dimensions ri=0.05m,r0=0.1m,and length is 1 m. i have applied temperature 573 k on inner radius and 323 k on outer surface.but,now i have some trouble in find the rate of heat loss from inner to outer...
can you help me??
Thanking you
parma
1 Reply Last Post Dec 25, 2011, 4:09 a.m. EST
Posted: 1 decade ago Dec 25, 2011, 4:09 a.m. EST
you problem is rather symmetric, depending only on "r" so applying Fourier heat law
q[W/m^2] = -k[W/m/K]*Grad(T)[K/m]
and taking into account the cylindrical coordinate transform, you get the heat flux (W per area) as
q = -k*(573-323)/(0.1-0.05)/ln(0.1/0.05)
or a q/k of about 7213.5 [K/m]
and that is what you see if you plot the heat flux magnitude in a cut plane, no ?
as you say nothing about the heat conductance "k" I have normalised over "k" (or you can use k=1 in COMSOL, and as you are in steady state "rho" and "Cp" are irrelevant, you can also use "1" as values there.
for the ln(Rext/Rint) I leave it to you to search on the web, there are several references there, and probably in your heat transfer text books too ;)
By the way you need to play a little with the mesh density to get a resonnable value, you could also try to use boundary elements, on the inner and outer surface, an easy way to get a denser mesh for better boundary temperature gradient, hence heat flux estimations, particularly in time dependent solving (less critical in steady state, ... why ?)
Hi you problem is rather symmetric, depending only on "r" so applying Fourier heat law q[W/m^2] = -k[W/m/K]*Grad(T)[K/m] and taking into account the cylindrical coordinate transform, you get the heat flux (W per area) as q = -k*(573-323)/(0.1-0.05)/ln(0.1/0.05) or a q/k of about 7213.5 [K/m] and that is what you see if you plot the heat flux magnitude in a cut plane, no ? as you say nothing about the heat conductance "k" I have normalised over "k" (or you can use k=1 in COMSOL, and as you are in steady state "rho" and "Cp" are irrelevant, you can also use "1" as values there. for the ln(Rext/Rint) I leave it to you to search on the web, there are several references there, and probably in your heat transfer text books too ;) By the way you need to play a little with the mesh density to get a resonnable value, you could also try to use boundary elements, on the inner and outer surface, an easy way to get a denser mesh for better boundary temperature gradient, hence heat flux estimations, particularly in time dependent solving (less critical in steady state, ... why ?) -- Good luck Ivar
