Copying Geometry steps to another comsol file.
Sanchayan Rajeetharan
Is it possible to copy the geometry part of the component and use it in another new COMSOL file.
Regards
2 Replies Last Post Feb 12, 2020, 2:24 a.m. EST
Posted: 5 years ago Feb 11, 2020, 5:14 p.m. EST
Hello Sanchayan,
Yes, you can do that easily. n the new file, right click on the Geometry node, then select Insert Sequence in the dropdown menu, and browse to the mph file which contains the geometry steps you want to bring into the new file.
Jeff Hiller
Hello Sanchayan, Yes, you can do that easily. n the new file, right click on the Geometry node, then select Insert Sequence in the dropdown menu, and browse to the mph file which contains the geometry steps you want to bring into the new file. Best, Jeff
Posted: 5 years ago Feb 12, 2020, 2:24 a.m. EST
Hello Sanchayan,
Thanks.
>Hello Sanchayan, > >Yes, you can do that easily. n the new file, right click on the Geometry node, then select Insert Sequence in the dropdown menu, and browse to the mph file which contains the geometry steps you want to bring into the new file. > >Best, > >Jeff Thanks.
