Wall contact problem will not converge
Posted Feb 21, 2020, 4:34 p.m. EST Structural Mechanics Version 5.5 2 Replies
Material 1 (domain 1) is cooling down by defined time dependant heat flux. as it reaches a certain temperature (solidification temperature) it is activated. next to the material there is a wall (domain 2) that will come into contact with the solidifying material because there is an inreasing pressure pushing the material into the wall. the mechanical and thermal stresses of the wall itself are of no interest to me, therefor it is thermally insulated and undeformable.
as the problem should be the same in each quarter of the whole geometry, i have used symmetry for both structural mechanics and heat transfer.
if you deactivate contact and nonlinearity in the solver, it converges and you can get an idea what will happen. as soon as i try to get the wall condition by defining contact between domain 1 and 2, it will not come to a solution.
I will attach the model and would be very thankful for any useful ideas.
Kind regards
