Maximum number of Newton iterations reached
Good day,
I am having this error after inputing a new function into the model. The new fucntion I inputied is the equation of density of CO2, which represent real gas condition, since what COMSOL has is CO2 ideal gas. Could someone help me finding out what is the problem?
Best regards, Nico
4 Replies Last Post Mar 2, 2020, 5:02 a.m. EST
Posted: 5 years ago Feb 27, 2020, 9:21 a.m. EST
Updated: 5 years ago Feb 27, 2020, 3:19 p.m. EST
Hi Nico,
You can increase the number of Newton iterations under "Study->Solver Configurations->Solver->Time-Dependent Solver->Fully Coupled". I usually set the maximum number of iterations to 25 and it works.
Cheers,
Alex
Hi Nico, You can increase the number of Newton iterations under "Study->Solver Configurations->Solver->Time-Dependent Solver->Fully Coupled". I usually set the maximum number of iterations to 25 and it works. Cheers, Alex
Posted: 5 years ago Feb 28, 2020, 3:29 a.m. EST
Thynk you for your answer,
I actually did that, however the simulation did not work. Not only increasing the iterations number, changging jacobian did not also help.
Nico
Thynk you for your answer, I actually did that, however the simulation did not work. Not only increasing the iterations number, changging jacobian did not also help. Best regards, Nico
Posted: 5 years ago Feb 28, 2020, 10:14 a.m. EST
Are you using a fully coupled solver? If so, you can try to change the nonlinear method to Automatic or Automatic Highly Nonlinear, which will slow down the simulation, but can help with nonlinear problems.
Cheers,
Alex
Are you using a fully coupled solver? If so, you can try to change the nonlinear method to Automatic or Automatic Highly Nonlinear, which will slow down the simulation, but can help with nonlinear problems. Cheers, Alex
Posted: 5 years ago Mar 2, 2020, 5:02 a.m. EST
Thank you for the answer. I have also tried that method, but still didnt work at all.
Nico
Thank you for the answer. I have also tried that method, but still didnt work at all. Best regards, Nico
