5 years ago
Feb 27, 2020, 3:10 p.m. EST
Updated:
5 years ago
Feb 27, 2020, 3:12 p.m. EST
Hi Manoj,
Do you mean that the mph file is 24 Gb AFTER the simulation? Also, are you running time dependent simulations? If so, then I would check your study configuration. More specifically, if your study settings time steps are set too small, then alot of solutions will be stored and your solved model will be vary large. Note that the "Times" in the study setting do not determine the time steps by the solver, but only the times saved for post-processing. Thus, I would set the "Times" to be the minimum amount need for post-processing.
Cheers,
Alex
Hi Manoj,
Cheers,
Alex
Robert Koslover
Certified Consultant
5 years ago
Feb 27, 2020, 4:37 p.m. EST
Some simulations, especially time-dependent 3D models with large numbers of degrees of freedom and where the results during many time steps are stored, consume a lot of disk space. I've had some single files exceed 100 GB in size. These are cumbersome, of course. I recommend that if you really need to create and execute such models, get some large internal solid state drives and some even larger (multi-TB) external high-speed (USB 3.0 or faster) disk drives to store your output files. Fortunately, external drives (especially the kind that require external power supplies) are much cheaper, and faster, than they used to be. You can add multi-TB to your overall file storage capacity at relatively low cost.
