Edgar J. Kaiser
Certified Consultant
4 years ago
Mar 26, 2020, 2:01 p.m. EDT
Sven,
sounds like this might be a contact pair.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Sven,
Cheers
Edgar
4 years ago
Mar 27, 2020, 4:21 a.m. EDT
Hi Edgar,
thanks for the reply.
Maybe, but wouldn´t it necessary to have a second geometry to create a contact pair?
This geometry would have to be meshed as wel, right?
I wanna avoid an additional geometry and thought there is a simple solution as described like a roller constraint with a free +z direction.
If not than something like that should be implemented in COMSOL because one need it very often.
BR Sven
Hi Edgar,
BR Sven
Henrik Sönnerlind
COMSOL Employee
4 years ago
Mar 27, 2020, 8:38 a.m. EDT
Hi Sven,
Adding that extra geometry and meshing it is a quick operation.
- Add a Workplane (maybe reorient it, but Z-normal is the default)
- Add a Square in that workplane, and set its size to be large enough
- Under Mesh, add a Mapped node, and select the newly generated square.
Now you can use the square as the Source in a contact pair.
Henrik Sönnerlind
COMSOL
Hi Sven,
1. Add a Workplane (maybe reorient it, but Z-normal is the default)
2. Add a Square in that workplane, and set its size to be large enough
3. Under Mesh, add a Mapped node, and select the newly generated square.
4 years ago
Mar 27, 2020, 9:18 a.m. EDT
Hi Henrik,
that sounds as if it could work=).
Thank you very much, I will try it like that.
BR Sven
Hi Henrik,
BR Sven
4 years ago
Mar 27, 2020, 2:00 p.m. EDT
Hi Henrik,
I tried your suggestions.
The plane and the square are fine and the meshing too.
Do I have to create the plane in a certain distance to the object or directly on the objects lower surface? Additionaly, if I wanna apply a fixed constraint to the square it´s not selectable (the square). Is this necessary at all? Or is this already implemented?
If the study doesn´t converge, what are the typical problems?
Thanks so far,
BR Sven
Hi Henrik,
Thanks so far,
BR Sven
