What is meant by the error "DAE is structurally inconsistent"?
Malik M Tahiyat Plasma Physics and Chemistry
I am trying to model a 2 D nonequilibrium plasma with an external Circuit. The same model works fine in 1D but when I try to make a 2D axisymmetric model, i get the error "DAE is structurally inconsistent". Can anyone give an idea where to start looking for?
Thanking you,
-Malik M Tahiyat
Graduate Research Assistant,
Department of Mechanical Engineering
University of South Carolina (USC)
300 Main Street, Room A 137
Phone: +1(803)-318-0274
2 Replies Last Post Apr 11, 2020, 6:47 p.m. EDT
Posted: 5 years ago Mar 29, 2020, 2:16 p.m. EDT
Usually when I see this error it is because of a floating electrical circuit node.
Posted: 5 years ago Apr 11, 2020, 6:47 p.m. EDT
Thanks Dave,
In my case, I found that I had not given some of the boundary conditions correctly and did not click on 'calculate from mass constraint' and 'calculate from electroneutrality constraint' at specific species in the plasma module.
I posted a new discussion. I would be grteful if you can take a look at my query.
Thanking you,
-Malik M Tahiyat
Thanks Dave, In my case, I found that I had not given some of the boundary conditions correctly and did not click on 'calculate from mass constraint' and 'calculate from electroneutrality constraint' at specific species in the plasma module. I posted a new discussion. I would be grteful if you can take a look at my query.
