Edgar J. Kaiser
Certified Consultant
5 years ago
Apr 16, 2020, 3:43 p.m. EDT
Marcel,
I think you could use two subsequent time dependent steps. A first one with small time steps to resolve the laser pulse and a second one with longer time steps for the rest.
Take the final result of the first time dependent step as initial condition for the second.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Marcel,
Cheers
Edgar
5 years ago
Apr 17, 2020, 3:41 a.m. EDT
Hello Edgar,
Thank you for your prompt reply.
I've already tried two time steps. The problem is that I have to look at the laser pulse for 0.1 s and during this time I cannot currently use any longer time steps because the pulse is then no longer recognized. For the cooling phase after drilling, I agree to work with different time steps. My problem is only the 0.1 s for the hole.
Best regards
Marcel
Hello Edgar,
Best regards
Marcel
Friedrich Maier
COMSOL Employee
5 years ago
Apr 17, 2020, 4:18 a.m. EDT
Updated:
5 years ago
Apr 17, 2020, 4:20 a.m. EDT
Dear Marcel,
there are varous possibilites you can try to control such models.
1: Use two study steps in your study. The first time dependent step with a small time resolution to capture the laser pulse and the second time dependent step with larger time stepping to capture the heat transfer
2: You can enter several sequential ranges e.g. range(0,0.001,.01) range(.02,.01,.1) in your times settings intervals. Please note that it could be important to control the time stepping:
https://www.comsol.com/support/knowledgebase/1254
3: You can benefit from the events interface.
https://www.comsol.com/support/knowledgebase/1245
Finally, if you have access to a COMSOL Multiphysics license under subscription please do not hesitate to contact the comsol support for such questions: https://www.comsol.de/support
Kind regards
Friedrich
Dear Marcel,
Kind regards
Friedrich
